[GRASS-dev] SESSION_MANAGER environment variable not defined
Paulo van Breugel p.vanbreugel at gmail.com
Mon Aug 1 08:02:01 PDT 2016
Hi all,
I switched from Ubuntu 14.04 to Ubuntu 16.04 and have just compiled
GRASS 7.3dev from source (r69054). It all seems to work fine, but at
start up I get the message:
/Debug: Failed to connect to session manager: SESSION_MANAGER
environment variable not defined/
GRASS was build with Python 2.7.12 and wxPython 3.0.2.0. In an earlier
email about the same debug message, it was suggested to set
/export SESSION_MANAGER=1/
Doing so before starting GRASS gives the same as reported by Andy:
/_IceTransOpen: Unable to Parse address 1//
//04:57:44 PM: Debug: Failed to connect to session manager: Could not
open network socket//
Up to now I don't see any further effects, so I am wondering if I could
/ should do any further testing?
Rgds,
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160801/0eeb190a/attachment-0001.html>
