[GRASS-dev] SESSION_MANAGER environment variable not defined
Markus Neteler neteler at osgeo.org
Mon Aug 1 15:09:44 PDT 2016
On Mon, Aug 1, 2016 at 5:02 PM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi all,
> I switched from Ubuntu 14.04 to Ubuntu 16.04 and have just compiled GRASS
> 7.3dev from source (r69054). It all seems to work fine, but at start up I
> get the message:
> Debug: Failed to connect to session manager: SESSION_MANAGER environment
The related wxwidgets ticket is
http://trac.wxwidgets.org/ticket/16024
but received a wontfix.
> GRASS was build with Python 2.7.12 and wxPython 3.0.2.0. In an earlier email
> about the same debug message, it was suggested to set
> export SESSION_MANAGER=1
For the record:
https://lists.osgeo.org/pipermail/grass-dev/2015-January/thread.html#72984
> Doing so before starting GRASS gives the same as reported by Andy:
> _IceTransOpen: Unable to Parse address 1
> 04:57:44 PM: Debug: Failed to connect to session manager: Could not open
> network socket
> Up to now I don't see any further effects, so I am wondering if I could /
> should do any further testing?
But does it start then or not?
Markus
