[GRASS-dev] SESSION_MANAGER environment variable not defined
Paulo van Breugel p.vanbreugel at gmail.com
Tue Aug 2 00:39:19 PDT 2016
On 02-08-16 00:09, Markus Neteler wrote:
> On Mon, Aug 1, 2016 at 5:02 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> Hi all,
>> I switched from Ubuntu 14.04 to Ubuntu 16.04 and have just compiled GRASS
>> 7.3dev from source (r69054). It all seems to work fine, but at start up I
>> get the message:
>> Debug: Failed to connect to session manager: SESSION_MANAGER environment
> The related wxwidgets ticket is
> http://trac.wxwidgets.org/ticket/16024
> but received a wontfix.
Ah, I hadn't seen the ticket, only the below referenced email tread.
>> GRASS was build with Python 2.7.12 and wxPython 3.0.2.0. In an earlier email
>> about the same debug message, it was suggested to set
>> export SESSION_MANAGER=1
> For the record:
> https://lists.osgeo.org/pipermail/grass-dev/2015-January/thread.html#72984
>> Doing so before starting GRASS gives the same as reported by Andy:
>> _IceTransOpen: Unable to Parse address 1
>> 04:57:44 PM: Debug: Failed to connect to session manager: Could not open
>> network socket
>> Up to now I don't see any further effects, so I am wondering if I could /
>> should do any further testing?
> But does it start then or not?
Yes, did some further testing, and all seems to work fine
> Markus
