[GRASS-dev] G6 manual pages: text box added to make users aware of G7
Markus Neteler neteler at osgeo.org
Thu Aug 18 08:32:24 PDT 2016
On Thu, Aug 18, 2016 at 2:53 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Thu, Aug 18, 2016 at 5:54 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> > I am not a developer, just something I wondered; why not having one
>> > permanent address for the manual, which always reflects the latest
>> > stable
>> > release, and if needed, from there add links to older versions?
>> > Obviously
>> > not a solution for now, but this would lead, in the future, to more
>> > stable
>> > and permanent rankings for the most up-to-date version.
>> +1
>> Perhaps simply this:
>> https://grass.osgeo.org/manuals/
>> https://grass.osgeo.org/manuals/addons
>> I could easily add that in the CMS and make it point to the current
>> stable version.
> If we can maintain the URL in the long term that would be great.
+1
> BTW, surprised to see "keywords index" as part of the "manuals" page.
It was an attempt to tell the CMSMS to index the manual pages. Seems
not to work.
> Unfortunately the links are broken:
> https://grass.osgeo.org/v.hull.html
Internally it is this "user tag" in CMSMS:
print file_get_contents("http://grass.osgeo.org/grass72/manuals/keywords.html");
which seems to eat the path. Ideas?
> Anyway, the above solution is better if we can have link like:
> https://grass.osgeo.org/manuals/v.hull.html
Yes.
> There is potential conflict of:
> https://grass.osgeo.org/grass70/manuals/grass7.html
> https://grass.osgeo.org/manuals/grass7.html
> but if the command will be `grass7` (or even `grass`) and the version always
> two numbers and the order is not changed to "manuals/grass70", no conflict
> will happen.
Two numbers would always solve it.
Markus
