[GRASS-dev] Python-based v.mapcalc to Addons
Sören Gebbert soerengebbert at googlemail.com
Tue Jan 5 02:23:01 PST 2016
+1
2016-01-05 8:47 GMT+01:00 Thomas Leppelt <thomas.leppelt at gmail.com>:
> Hi Vaclav,
> it would be nice, if you commit v.mapcalc to Addons.
> Thanks
> Thomas
> On Tue, Jan 5, 2016 at 4:52 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> Hi Soeren,
>> I've tried v.mapcalc from Thomas' GSoC and I think it should go at least
>> to Addons. Does one of you want to commit it or should I do that? Some,
>> rather trivial, changes are need to make it work (attached), I can apply
>> them later if you want.
>> I also suggest removing the v.mapcalc which is now in addons. Perhaps the
>> functionality is different but since it was not finished, there is no
>> functionality which can be used. Unless somebody will work on it soon, I
>> don't see a reason to keep it there. (Alternatively, it can be renamed.)
>> Best,
>> Vaclav
>> On Tue, Oct 13, 2015 at 3:15 AM, Sören Gebbert
>> <soerengebbert at googlemail.com> wrote:
>>> Hi,
>>> the GSoC implementation of v.mapcalc is still available:
>>> https://code.google.com/p/grass-gis-temporal-algebra/source/browse/#svn%2Ftrunk%2Fv.mapcalc
>>> However, the approach in the GSoC v.mapcalc is very different from the
>>> v.mapcalc addon from 2002.
>>> The algebraic expressions are applied to whole vector maps, rather
>>> than single points, list of points, lines or polygons.
>>> Best regards
>>> Soeren
>>> 2015-10-13 3:53 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>>> > On Mon, Oct 12, 2015 at 6:24 AM, Glynn Clements
>>> > <glynn at gclements.plus.com>
>>> > wrote:
>>> >> Markus Neteler wrote:
>>> >> > <p.vanbreugel at gmail.com> wrote:
>>> >> > > Sorry for the late follow up. The add-on installs now. When trying
>>> >> > > to
>>> >> > > run
>>> >> > > it, however, nothing happens.
>>> >> > It does not have a parser (yet?), so I suppose it reads from stdin.
>>> >> Yes.
>>> >> But it doesn't have any code to read or write GRASS vectors, either.
>>> >> v.mapcalc appears to be a work-in-progress which hasn't actually made
>>> >> noticeable progress since it was added.
>>> > Then I suggest to remove it from the Makefile parent directory and also
>>> > disable it in the addons build scripts if there is something more
>>> > needed
>>> > than r66406 [1] which is blacklisting it somehow already. It does not
>>> > fulfill what user would expect (at least some functionality). Those who
>>> > want
>>> > to continue development will get it through svn.
>>> > I'm not sure happened [2] with the v.mapcalc implemented as a test case
>>> > in
>>> > GSoC [3] and if the functionality can be still used. But this seems
>>> > like a
>>> > good alternative to the code in addons.
>>> > Vaclav
>>> > [1] https://trac.osgeo.org/grass/changeset/66406
>>> > [2]
>>> > https://lists.osgeo.org/pipermail/grass-dev/2013-October/065908.html
>>> > [3]
>>> > https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2013_Temporal_GIS_Algebra_for_raster_and_vector_data_in_GRASS#v.mapcalc
>>> > _______________________________________________
>>> > grass-dev mailing list
>>> > grass-dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
