[GRASS-dev] Python-based v.mapcalc to Addons
Vaclav Petras wenzeslaus at gmail.com
Tue Jan 5 19:49:20 PST 2016
On Tue, Jan 5, 2016 at 2:47 AM, Thomas Leppelt <thomas.leppelt at gmail.com>
wrote:
> it would be nice, if you commit v.mapcalc to Addons.
Done.
Rename v.mapcalc to v.feature.algebra and disable it:
https://trac.osgeo.org/grass/changeset/67492
https://trac.osgeo.org/grass/changeset/67493
Add and update Python v.mapcalc:
https://trac.osgeo.org/grass/changeset/67494
https://trac.osgeo.org/grass/changeset/67495
https://trac.osgeo.org/grass/changeset/67496
> On Tue, Jan 5, 2016 at 4:52 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> I've tried v.mapcalc from Thomas' GSoC and I think it should go at least
>> to Addons. Does one of you want to commit it or should I do that? Some,
>> rather trivial, changes are need to make it work (attached), I can apply
>> them later if you want.
>> I also suggest removing the v.mapcalc which is now in addons. Perhaps the
>> functionality is different but since it was not finished, there is no
>> functionality which can be used. Unless somebody will work on it soon, I
>> don't see a reason to keep it there. (Alternatively, it can be renamed.)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160105/406bff26/attachment.html>
