[GRASS-dev] Python-based v.mapcalc to Addons
Vaclav Petras wenzeslaus at gmail.com
Tue Jan 5 20:50:45 PST 2016
Hi Martin,
I see that the Addons index page was compiled but don't see any changes
(there, in individual pages or in logs). Can you please look at that? I was
changing the directory Makefile and renaming directories, so I'm not sure
if this could cause something.
Vaclav
On Tue, Jan 5, 2016 at 10:49 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Tue, Jan 5, 2016 at 2:47 AM, Thomas Leppelt <thomas.leppelt at gmail.com>
> wrote:
>> it would be nice, if you commit v.mapcalc to Addons.
> Done.
> Rename v.mapcalc to v.feature.algebra and disable it:
> https://trac.osgeo.org/grass/changeset/67492
> https://trac.osgeo.org/grass/changeset/67493
> Add and update Python v.mapcalc:
> https://trac.osgeo.org/grass/changeset/67494
> https://trac.osgeo.org/grass/changeset/67495
> https://trac.osgeo.org/grass/changeset/67496
>> On Tue, Jan 5, 2016 at 4:52 AM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> I've tried v.mapcalc from Thomas' GSoC and I think it should go at least
>>> to Addons. Does one of you want to commit it or should I do that? Some,
>>> rather trivial, changes are need to make it work (attached), I can apply
>>> them later if you want.
>>> I also suggest removing the v.mapcalc which is now in addons. Perhaps
>>> the functionality is different but since it was not finished, there is no
>>> functionality which can be used. Unless somebody will work on it soon, I
>>> don't see a reason to keep it there. (Alternatively, it can be renamed.)
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160105/8781b788/attachment.html>
