[GRASS-dev] does GRASS need HOME to be defined?
Helmut Kudrnovsky hellik at web.de
Sun Nov 20 10:39:25 PST 2016
as a follow up of:
https://lists.osgeo.org/pipermail/grass-dev/2016-November/083125.html
[snip]
>>> what happens if we don't set it in grass.py? I can't try now.
>> tested in winGRASS7.0.5 by commenting out following line:
>> # set HOME
>> #if windows and not os.getenv('HOME'):
>> #    os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
>> #                                        os.getenv('HOMEPATH'))
>> in C:\Program Files\GRASS GIS 7.0.5\etc\grass70.py
>> the wxGUI starts, displaying raster and vector works, tested some
>> modules,
>> all worked.
>> but no idea if there may be some more side effect; further no idea if
>> there
>> is probably more to do for the OSGeo4W-version.
>> anyone more insight, if %HOME% is needed in winGRASS?
>Done by Glynn in:
>https://trac.osgeo.org/grass/changeset/37873
any hints?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/does-GRASS-need-HOME-to-be-defined-tp5296669.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
