[GRASS-dev] New attempt to update GRASS for Mac
Vaclav Petras wenzeslaus at gmail.com
Thu Aug 3 12:53:52 PDT 2017
On Thu, Aug 3, 2017 at 3:39 PM, Michael Barton <Michael.Barton at asu.edu>
wrote:
> Working with a very helpful software engineer at CSDMS here in Boulder,
> we've decided that a good way to work out a new and more sustainable way to
> create binaries would be to compile GRASS under Anaconda. We could then
> more easily package GRASS and all dependencies, and subsequently make it
> into an Anaconda package for those who'd like to install it that way.
Glad to hear that you are moving forward. Sounds like a promising solution
for Mac and there already were people suggesting Anaconda in general.
> So far, we've successfully installed all dependencies AFAICT and
> successfully configured it. But we have not yet been able to compile
> without errors.
> I can send config string and full build output if helpful, but thought I'd
> start here.
Is there any way you can do reproduce your Anaconda experiments using a
Linux machine in Docker and share the Dockerfile?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170803/18d0be4f/attachment-0001.html>
