[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
Vaclav Petras wenzeslaus at gmail.com
Mon Feb 6 06:43:27 PST 2017
On Mon, Feb 6, 2017 at 8:52 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Feb 6, 2017 at 8:52 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> > Markus Neteler <neteler at osgeo.org> writes:
> > How do you mean? The script is in the folder .travis (hidden to be
> > in line with the naming of the .travis.yml file and as it is of no
> > importance for GRASS itself). There were the scripts (see changeset
> > https://trac.osgeo.org/grass/changeset/70483 )
> Yes - I was just wondering where the "svn" call is located which I
> cannot see in these scripts.
That's the reason it should not be done the way that the travis test/build
(.travis.yml) in the main repo (its git copy) uses code which is actually
in a different repo (the Homebrew recipe) and is downloaded again for the
test (from Subversion repo in this case). Unless there are strong reasons
to do it otherwise, the test/build instructions in the main repo should
trigger builds which are based only on the code from that repo.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170206/8e0c4d38/attachment.html>
