[GRASS-dev] v.surf.bspline density and distance estimates
Paulo van Breugel p.vanbreugel at gmail.com
Sun Jun 18 23:42:12 PDT 2017
On 6/16/17 3:20 PM, Markus Metz wrote:
> On Fri, Jun 16, 2017 at 11:28 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > Hi devs, can anybody tell how v.surf.bspline computes the point
> density and mean distance.
> point density is the number of points divided by the size of the
> bounding box of the points
> mean distance is the square root of the size of the bounding box
> divided by the number of points
> > And what is the unit, pixels, as also used for length spline steps
> or meters?
> the unit is map unit, you can then figure out a reasonable resolution
> (in map units) for the current region
Thanks!
I was trying to find out from the source code, but not understanding C I
couldn't find where this was described / done.
> Markus M
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170619/e1c312f9/attachment.html>
