[GRASS-dev] v.surf.bspline density and distance estimates
Paulo van Breugel p.vanbreugel at gmail.com
Sat Jun 24 02:23:42 PDT 2017
On 6/16/17 3:20 PM, Markus Metz wrote:
> On Fri, Jun 16, 2017 at 11:28 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > Hi devs, can anybody tell how v.surf.bspline computes the point
> density and mean distance.
> point density is the number of points divided by the size of the
> bounding box of the points
> mean distance is the square root of the size of the bounding box
> divided by the number of points
> > And what is the unit, pixels, as also used for length spline steps
> or meters?
> the unit is map unit, you can then figure out a reasonable resolution
> (in map units) for the current region
I think it would be good to add your explanation to the manual page. I
was trying to come up with a text, but then I realized there is still
some ambiguity left.
According to the manual page, the ns_step and ew_step parameters are in
pixels (which I would interpret as 'number of pixels'). However, the
example of 'Basic interpolation and raster output with a longer spline
step' in the manual page talks about mapping units.
v.surf.bspline input=point_vector raster=interpolate_surface ew_step=25
ns_step=25
A bilinear spline interpolation will be done with a spline step length
of 25 map units.
So if the region's resolution is 100 meter, is the ns_step and ew_step
2500 meter (25 pixels) or 25 meters? The former would be more conform
common practice in grass I think.
> Markus M
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170624/d40e37d2/attachment.html>
