[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
Vincent Bain bain at toraval.fr
Wed Sep 20 07:39:55 PDT 2017
looks like this problem appeared some time ago :
https://lists.osgeo.org/pipermail/grass-user/2016-August/074641.html
As Robert asked, is there a way to set, at least temporarily, the
verbosity of these messages ?
V.
Le mercredi 20 septembre 2017 à 15:44 +0200, Vincent Bain a écrit :
> wxPython: 3.0.2.0
> My old debian 8.8 install has wxPython: 3.0.1.1
> On another hand, trying to find out what was new between debian 9.0 and
> debian 8.8 configurations, I noticed there was a difference concerning
> wx-config alternatives:
>         - in the former it pointed towards
>         /usr/lib/i386-linux-gnu/wx/config/base-unicode-3.0
>         - while in the newer it points toward
>         /usr/lib/i386-linux-gnu/wx/config/gtk2-unicode-3.0
> I tried to rebuild (after a distclean) with the previous configuration,
> i.e. base-unicode-3.0
>         $ update-alternatives --config wx-config
> but the error still rises.
> Perhaps I should try to revert to wxPython 3.0.1.1
> Vincent.
> Le mercredi 20 septembre 2017 à 15:23 +0200, Markus Neteler a écrit :
> > On Wed, Sep 20, 2017 at 2:01 PM, Vincent Bain <bain at toraval.fr> wrote:
> > > after digging it a little bit deeper, I guess it has rather something to
> > > do with the environment : I currently work on different debian machines;
> > > the issue happens when I build the latest trunk version (r:71500) on a
> > > new/clean debian 9 (stretch). Building the same release on my old debian
> > > 8 works fine.
> > Please check the wxPython version, through g.gui > Help > About system
> > Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
