[GRASS-dev] [GRASS GIS] #3496: v.in.pdal: does not compile with PDAL 1.6.0
GRASS GIS trac at osgeo.org
Thu Feb 15 06:49:15 PST 2018
 Reporter:  felixg                  |      Owner:  grass-dev@…
     Type:  defect                  |     Status:  new
 Priority:  normal                  |  Milestone:
Component:  Vector                  |    Version:  unspecified
 Keywords:  v.in.pdal, PDAL, lidar  |        CPU:  Unspecified
 Platform:  Unspecified             |
 As the PDAL API changed in a few places, the code of v.in.pdal fails to
 compile and needs to be adjusted.
 The attached patch file changes the following in `main.cpp` of v.in.pdal:
 - the includes as PDAL relocated some header files
 - use of the enum pdal::Dimension::Id
 - a method call to pdal::SpatialReference::getWKT(), it does not have any
 formal parameters anymore in PDAL
Ticket URL: <https://trac.osgeo.org/grass/ticket/3496>
