[GRASS-dev] Issue with double conditional in r.mapcalc (WinGRASS) and real life test of the aconda 7.5dev on Mac
Helmut Kudrnovsky hellik at web.de
Sun Feb 18 14:10:28 PST 2018
>r.mapcalc expression=if(case1,if(case2,Val2True,Val2False),Val1False))
>This expression will fail, note that the lack of quote is intentional, as
it is a requirement to run simpler >r.mapcalc statements in WinGRASS.
when, in winGRASS, I copy from r.mapcalc:
r.mapcalc expression="rbstreams500 = if( bstreams500 at yann == 2, 1, 0)"
the term is quoted.
when I do in the wxGUI console
r.mapcalc expression=rbstreams500unquoted = if( bstreams500 at yann == 2, 1, 0)
I get an "unable to parse..." error.
how do you conclude that "it is a requirement to run simpler r.mapcalc
statements in winGRASS"?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
