[GRASS-dev] Issue with double conditional in r.mapcalc (WinGRASS) and real life test of the aconda 7.5dev on Mac
Helmut Kudrnovsky hellik at web.de
Sun Feb 18 14:27:37 PST 2018
>We used the tutorial in grass=promo/tuorials/grassstarter, the script at the
end essentially, running on >Spearfish dataset.
hopefully found the right cmds (easier would be posting directly the
commands here).
workflow here in winGRASS7.4.0:
r.buffer input=streams at PERMANENT output=bstreams500 distances=500
r.null map=bstreams500 at yann null=0
r.buffer input=roads at PERMANENT output=broads500 distances=500
r.null map=broads500 at yann null=0
r.mapcalc expression="rbstreams500 = if( bstreams500 at yann == 2, 1, 0)"
r.info map=slope at PERMANENT
|   Range of data:    min = 0  max = 52.52016
r.mapcalc expression="s_sl = if( rbstreams500 at yann == 1, if( slope <= 5, 2,
5), 0)"
>This expression will fail, note that the lack of quote is intentional, as
it is a requirement to run simpler >r.mapcalc statements in WinGRASS.
r.info map=s_sl at yann
 | Map:      s_sl at yann                      Date: Sun Feb 18 23:14:50 2018
 | Mapset:   yann                           Login of Creator: hkmyr
 | DataBase: D:\grassdata
 | Title:    s_sl
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         466
 |   Columns:      633
 |   Total Cells:  294978
 |        Projection: UTM (zone 13)
 |            N:    4928000    S:    4914020   Res:    30
 |            E:     609000    W:     590010   Res:    30
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    if(rbstreams500 at yann == 1, if(slope <= 5, 2, 5), 0)
 r.stats -c -n input=s_sl at yann
0 109746
2 41812
5 140733
what should be the expected result of your calculations? are these different
to my calculations in winGRASS7.4.0.
a well described workflow and expected results would be helpfull for testing
if winGRASS 7.4.0 really fails here?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
