[GRASS-dev] compiling in debian 8 fails in r.sunmask and r.support
Helmut Kudrnovsky hellik at web.de
Fri Feb 23 08:15:50 PST 2018
hi,
fresh svn up and make clean, any idea why compilations may fail:
Started compilation: Fr 23. Feb 16:55:33 CET 2018
Errors in:
/home/bugs/dev/cpp/grass7_trunk/raster/r.sunmask
/home/bugs/dev/cpp/grass7_trunk/raster/r.support
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Fr 23. Feb 17:08:15 CET 2018
Makefile:57: die Regel für Ziel „default“ scheiterte
make: *** [default] Fehler 1
bugs at nada:~/dev/cpp/grass7_trunk$ cd raster/r.sun
r.sun/      r.sunhours/ r.sunmask/
bugs at nada:~/dev/cpp/grass7_trunk$ cd raster/r.sunmask/
bugs at nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ make
if [
"/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask" !=
"" ] ; then
GISRC=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc75
GISBASE=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu
PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C LANG=C LANGUAGE=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.sunmask.tmp.html ; fi
/bin/sh: 1:
/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask:
Permission denied
../../include/Make/Html.make:14: die Regel für Ziel „r.sunmask.tmp.html“
scheiterte
make: *** [r.sunmask.tmp.html] Fehler 1
rm r.sunmask.tmp.html
bugs at nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ cd ..
bugs at nada:~/dev/cpp/grass7_trunk/raster$ cd r.support
bugs at nada:~/dev/cpp/grass7_trunk/raster/r.support$ make
if [
"/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support" !=
"" ] ; then
r.support.tmp.html ; fi
/bin/sh: 1:
/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support:
Permission denied
../../include/Make/Html.make:14: die Regel für Ziel „r.support.tmp.html“
scheiterte
make: *** [r.support.tmp.html] Fehler 1
rm r.support.tmp.html
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
