[GRASS-dev] compiling in debian 8 fails in r.sunmask and r.support
Helmut Kudrnovsky hellik at web.de
Fri Feb 23 08:57:27 PST 2018
Helmut Kudrnovsky wrote
> hi,
> fresh svn up and make clean, any idea why compilations may fail:
> Started compilation: Fr 23. Feb 16:55:33 CET 2018
> Errors in:
> /home/bugs/dev/cpp/grass7_trunk/raster/r.sunmask
> /home/bugs/dev/cpp/grass7_trunk/raster/r.support
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Fr 23. Feb 17:08:15 CET 2018
> Makefile:57: die Regel für Ziel „default“ scheiterte
> make: *** [default] Fehler 1
> bugs at nada:~/dev/cpp/grass7_trunk$ cd raster/r.sun
> r.sun/      r.sunhours/ r.sunmask/
> bugs at nada:~/dev/cpp/grass7_trunk$ cd raster/r.sunmask/
> bugs at nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ make
> if [
> "/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask"
> "" ] ; then
> GISRC=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc75
> GISBASE=/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu
> PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH"
> PYTHONPATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/lib:"
> LC_ALL=C LANG=C LANGUAGE=C
> --html-description < /dev/null | grep -v '
> </body>
> </html>
> r.sunmask.tmp.html ; fi
> /bin/sh: 1:
> /home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.sunmask:
> Permission denied
> ../../include/Make/Html.make:14: die Regel für Ziel „r.sunmask.tmp.html“
> scheiterte
> make: *** [r.sunmask.tmp.html] Fehler 1
> rm r.sunmask.tmp.html
> bugs at nada:~/dev/cpp/grass7_trunk/raster/r.sunmask$ cd ..
> bugs at nada:~/dev/cpp/grass7_trunk/raster$ cd r.support
> bugs at nada:~/dev/cpp/grass7_trunk/raster/r.support$ make
> if [
> "/home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support"
> "" ] ; then
> </body>
> </html>
> r.support.tmp.html ; fi
> /bin/sh: 1:
> /home/bugs/dev/cpp/grass7_trunk/dist.x86_64-pc-linux-gnu/bin/r.support:
> Permission denied
> ../../include/Make/Html.make:14: die Regel für Ziel „r.support.tmp.html“
> scheiterte
> make: *** [r.support.tmp.html] Fehler 1
> rm r.support.tmp.html
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
sorry for the noise, a second make clean/make distclean helped; compiling
now without an issue
best regards
Helmut
