[GRASS-dev] compile 6S library in GRASS
Roberta Fagandini robifagandini at gmail.com
Wed Jun 27 04:20:48 PDT 2018
Hi all!
I need to compile the 6S library in GRASS in order to install the python
library Py6S [0].
The source code of 6S (v 1.1) is written in Fortran and it seems to be the
same code used for i.atcorr but I can't see the Fortran source code within
the GRASS svn [1]. In fact, I can't find the 6S executable on my disk even
if I installed GRASS.
Thanks in advance!
Roberta
[0]
http://py6s.readthedocs.io/en/latest/installation.html#alternative-manual-installation
[1] https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/c7786d6f/attachment.html>
