[GRASS-dev] compile 6S library in GRASS
Yann Chemin dr.yann.chemin at gmail.com
Wed Jun 27 04:24:54 PDT 2018
6s was rewritten by Cristo in C++
The code was absorbed in i.atcorr around the beginning of the century.
On Wed, Jun 27, 2018, 13:20 Roberta Fagandini <robifagandini at gmail.com>
wrote:
> Hi all!
> I need to compile the 6S library in GRASS in order to install the python
> library Py6S [0].
> The source code of 6S (v 1.1) is written in Fortran and it seems to be the
> same code used for i.atcorr but I can't see the Fortran source code within
> the GRASS svn [1]. In fact, I can't find the 6S executable on my disk even
> if I installed GRASS.
> Thanks in advance!
> Roberta
> [0]
> http://py6s.readthedocs.io/en/latest/installation.html#alternative-manual-installation
> [1] https://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180627/010c395a/attachment.html>
