[GRASS-dev] [GRASS-SVN] r74423 - grass/trunk/raster/r.basins.fill/testsuite
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Wed Apr 24 15:03:09 PDT 2019
Hi Markus,
Unfortunately, the test will have to be more or less rewritten, which is why I for now chose to deactivate it with an info message pointing to the related ticket.
Alternatively, it could be shortened to the one assertModule test that it actually performs on r.basin.fill (see also comments in the ticket).
Also skipped tests should remain visible in test reports e.g. on fatra BTW.
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Markus Neteler
Sent: onsdag 24. april 2019 22:45
To: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] [GRASS-SVN] r74423 - grass/trunk/raster/r.basins.fill/testsuite
Hi Stefan,
<svn_grass at osgeo.org<mailto:svn_grass at osgeo.org>> schrieb am Mi., 24. Apr. 2019, 22:41:
Author: sbl
Date: 2019-04-24 13:41:37 -0700 (Wed, 24 Apr 2019)
New Revision: 74423
grass/trunk/raster/r.basins.fill/testsuite/testrbf.py
deactivate erroneous test; see #3822
Modified: grass/trunk/raster/r.basins.fill/testsuite/testrbf.py
--- grass/trunk/raster/r.basins.fill/testsuite/testrbf.py 2019-04-24 20:33:36 UTC (rev 74422)
+++ grass/trunk/raster/r.basins.fill/testsuite/testrbf.py 2019-04-24 20:41:37 UTC (rev 74423)
@@ -8,8 +8,10 @@
License (>=v2). Read the file COPYING that comes with GRASS
for details.
+import unittest
from grass.gunittest.case import TestCase
+ at unittest.skip("See<mailto:+ at unittest.skip(%22See> #3822")
class TestRasterbasin(TestCase):
celevation='elevation'
tgeology='geology'
Did you see the attachment?
I'd prefer to fix the test rather than skip it (and forget)...
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190424/2e1ada5d/attachment.html>
