[GRASS-dev] extra verbosity in temporal commands
Anna Petrášová kratochanna at gmail.com
Mon Jul 29 20:06:26 PDT 2019
Sorry, yes, I must have left it there. Should be fixed now.
Anna
On Mon, Jul 29, 2019 at 9:31 PM Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hi Vashek,
> No, I haven't changed anything with g.gisenv. There were not recent
> changes in the temporal stuff that I am aware of. Maybe some forgotten
> debug messages/prints in more low level python library change?? No idea, I
> just started noticing last week in a two weeks old grass77.
> I haven't tried it. Is it supposed to work with all modules? The same
> command I showed before with --qq gives error "that's not a valid flag"
> Vero
> El mar., 30 jul. 2019 a las 2:05, Vaclav Petras (<wenzeslaus at gmail.com>)
> escribió:
>> On Mon, Jul 29, 2019 at 7:45 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hi devs,
>>> I have noticed since last week or so that every time I run a temporal
>>> command, it clutters my terminal with "internal" stuff from the module. I
>>> have not changed verbosity level. Could it be that some library change
>>> produced that or some remaining debugging setting??
>>> Here's an example of what I see:
>>> .rast.series input=month_max_LST_per_year   output=slope_month_max_LST
>>> method=slope --o
>>>  100%
>>> UPDATE raster_base SET  name = 'slope_month_max_LST'  ,creator =
>>> 'veroandreo'  ,mapset = 'modis_lst'  ,creation_time = '2019-07-30
>>> 01:40:56.813449'  ,temporal_type = 'absolute'  ,id =
>>> 'slope_month_max_LST at modis_lst' WHERE id =
>>> 'slope_month_max_LST at modis_lst';
>>> UPDATE raster_absolute_time SET  start_time = '2015-01-01 00:00:00'  ,id
>>> = 'slope_month_max_LST at modis_lst'  ,end_time = '2018-01-01 00:00:00'
>>> WHERE id = 'slope_month_max_LST at modis_lst';
>>> UPDATE raster_spatial_extent SET  north = 323380.124115  ,bottom =
>>> 0.000000  ,west = 122934.464115  ,top = 0.000000  ,proj = 'XY'  ,east =
>>> 934934.464115  ,id = 'slope_month_max_LST at modis_lst'  ,south =
>>> 9780.124115 WHERE id = 'slope_month_max_LST at modis_lst';
>>> UPDATE raster_metadata SET  max = 1.500000  ,rows = 145  ,min =
>>> -2.000000  ,datatype = 'DCELL'  ,number_of_cells = 8120  ,cols = 56  ,ewres
>>> = 5600.000000  ,nsres = 5600.000000  ,id = 'slope_month_max_LST at modis_lst'
>>> UPDATE raster_stds_register SET  id = 'slope_month_max_LST at modis_lst'
>>>  ,registered_stds = NULL WHERE id = 'slope_month_max_LST at modis_lst';
>>> Any hints?
>> Hi Vero,
>> This looks like some forgotten debug messages/prints, but just to be
>> sure, first check that you did not switch on debug mode (g.gisenv). I don't
>> see changes in temporal code, but perhaps I'm missing something.
>> Related to that (from user perspective), have you tried --qq recently? It
>> didn't seem to work for me.
>> Vaclav
>>> Vero
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190729/773540e4/attachment.html>
