[GRASS-dev] extra verbosity in temporal commands
Veronica Andreo veroandreo at gmail.com
Tue Jul 30 05:27:33 PDT 2019
Great! Thanks, Anna!
El mar., 30 jul. 2019 a las 5:06, Anna Petrášová (<kratochanna at gmail.com>)
escribió:
> Sorry, yes, I must have left it there. Should be fixed now.
> Anna
> On Mon, Jul 29, 2019 at 9:31 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi Vashek,
>> No, I haven't changed anything with g.gisenv. There were not recent
>> changes in the temporal stuff that I am aware of. Maybe some forgotten
>> debug messages/prints in more low level python library change?? No idea, I
>> just started noticing last week in a two weeks old grass77.
>> I haven't tried it. Is it supposed to work with all modules? The same
>> command I showed before with --qq gives error "that's not a valid flag"
>> Vero
>> El mar., 30 jul. 2019 a las 2:05, Vaclav Petras (<wenzeslaus at gmail.com>)
>> escribió:
>>> On Mon, Jul 29, 2019 at 7:45 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hi devs,
>>>> I have noticed since last week or so that every time I run a temporal
>>>> command, it clutters my terminal with "internal" stuff from the module. I
>>>> have not changed verbosity level. Could it be that some library change
>>>> produced that or some remaining debugging setting??
>>>> Here's an example of what I see:
>>>> .rast.series input=month_max_LST_per_year   output=slope_month_max_LST
>>>>   method=slope --o
>>>>  100%
>>>> UPDATE raster_base SET  name = 'slope_month_max_LST'  ,creator =
>>>> 'veroandreo'  ,mapset = 'modis_lst'  ,creation_time = '2019-07-30
>>>> 01:40:56.813449'  ,temporal_type = 'absolute'  ,id =
>>>> 'slope_month_max_LST at modis_lst' WHERE id =
>>>> 'slope_month_max_LST at modis_lst';
>>>> UPDATE raster_absolute_time SET  start_time = '2015-01-01 00:00:00'
>>>>  ,id = 'slope_month_max_LST at modis_lst'  ,end_time = '2018-01-01
>>>> 00:00:00' WHERE id = 'slope_month_max_LST at modis_lst';
>>>> UPDATE raster_spatial_extent SET  north = 323380.124115  ,bottom =
>>>> 0.000000  ,west = 122934.464115  ,top = 0.000000  ,proj = 'XY'  ,east =
>>>> 934934.464115  ,id = 'slope_month_max_LST at modis_lst'  ,south =
>>>> 9780.124115 WHERE id = 'slope_month_max_LST at modis_lst';
>>>> UPDATE raster_metadata SET  max = 1.500000  ,rows = 145  ,min =
>>>> -2.000000  ,datatype = 'DCELL'  ,number_of_cells = 8120  ,cols = 56  ,ewres
>>>> = 5600.000000  ,nsres = 5600.000000  ,id = 'slope_month_max_LST at modis_lst'
>>>> UPDATE raster_stds_register SET  id = 'slope_month_max_LST at modis_lst'
>>>>  ,registered_stds = NULL WHERE id = 'slope_month_max_LST at modis_lst';
>>>> Any hints?
>>> Hi Vero,
>>> This looks like some forgotten debug messages/prints, but just to be
>>> sure, first check that you did not switch on debug mode (g.gisenv). I don't
>>> see changes in temporal code, but perhaps I'm missing something.
>>> Related to that (from user perspective), have you tried --qq recently?
>>> It didn't seem to work for me.
>>> Vaclav
>>>> Vero
>>>> _______________________________________________
>>>> grass-dev mailing list
>>>> grass-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190730/809635a3/attachment-0001.html>
