[GRASS-dev] db.copy gives error
    Markus Metz
    markus.metz.giswork at gmail.com
    Sat Mar 14 15:38:58 PDT 2020
On Sat, Mar 14, 2020 at 3:27 PM Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Dear devs,
> I have a grassgis database with in the mapset 'Permanent' a table
> 'vegetation_lookup'. I want top copy this table to the current mapset.
> The following used to work I think, but now gives me some errors:
> db.copy from_driver=sqlite
> from_database=/media/grassdb/biodiv/PERMANENT/sqlite/sqlite.db
> from_table=vegetation_lookup to_driver=sqlite
> to_database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> to_table=vegetation_lookup
Looking at the code of db.copy, it is not possible that this ever worked,
you need to replace the variables with their actual values.
Markus M
> ERROR: Unable to create directory '///sqlite' for sqlite database
> dbmi: Protocol error
> WARNING: Unable to open database <///sqlite/sqlite.db> by driver <sqlite>
> Any idea what I am doing wrong here?
> With kind regards,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200314/1106b054/attachment.html>
