[GRASS-dev] Use # %, not #% in Python scripts
Markus Metz
markus.metz.giswork at gmail.com
Fri Feb 5 11:35:29 PST 2021
On Fri, Feb 5, 2021 at 5:14 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Dear all,
> I prepared a change to g.parser and related code which changes the option
definitions in scripts (aka script header) from:
> #%option
> #% key
> #%end
> to:
> # %option
> # % key
> # %end
> The reason is PEP8 compliance where "each line of a block comment starts
with a # and a single space" [2].
> The PR is removing all use of #% from the code, but it is still allowed,
so addons and existing user code should continue to work. However, I don't
see a need to depreciate support of #% at this point.
> This change moves us a little closer to PEP8 or Flake8 compliance. We can
now enable the check in CI once the normal comments are fixed. (The file
header comment is ignored, so no need to change that, but we can consider
that anyway.)
> The vision is that users and contributors can write scripts which just
work with more or less default Flake8 settings. This is a big step towards
that because it removes tens of warnings for a standard module.
These warnings for #% are a real annoyance, distracting from meaningful
warnings. The suggested changes will make code quality checking and code
improvement much easier.
+1
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210205/bd9280cf/attachment.html>
