[GRASS-dev] Use # %, not #% in Python scripts
Vaclav Petras wenzeslaus at gmail.com
Mon Feb 8 20:31:00 PST 2021
On Fri, Feb 5, 2021 at 2:35 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Feb 5, 2021 at 5:14 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> > Dear all,
> > I prepared a change to g.parser and related code which changes the
> option definitions in scripts (aka script header) from:
> > #%option
> > #% key
> > #%end
> > to:
> > # %option
> > # % key
> > # %end
> > The reason is PEP8 compliance where "each line of a block comment starts
> with a # and a single space" [2].
> > The PR is removing all use of #% from the code, but it is still allowed,
> so addons and existing user code should continue to work. However, I don't
> see a need to depreciate support of #% at this point.
> > This change moves us a little closer to PEP8 or Flake8 compliance. We
> can now enable the check in CI once the normal comments are fixed. (The
> file header comment is ignored, so no need to change that, but we can
> consider that anyway.)
> > The vision is that users and contributors can write scripts which just
> work with more or less default Flake8 settings. This is a big step towards
> that because it removes tens of warnings for a standard module.
> These warnings for #% are a real annoyance, distracting from meaningful
> warnings. The suggested changes will make code quality checking and code
> improvement much easier.
> +1
Thanks for the feedback. The change is now merged.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210208/d0fc1e52/attachment.html>
