[GRASS-dev] multiprocessing problem
Luca Delucchi lucadeluge at gmail.com
Sun Apr 10 22:15:50 PDT 2022
On Fri, 8 Apr 2022 at 11:17, Stefan Blumentrath
<Stefan.Blumentrath at nina.no> wrote:
> Ciao Luca,
Ciao Stefan
> Yes, you could also consider looping over e.g. rows (maybe in combination with "np.apply_along_axis") so you could put results easier back together to a map if needed at a later stage.
> In addition, since you use multiprocessing.Manager, you may try to use multiprocessing.Array: https://docs.python.org/3/library/multiprocessing.html#multiprocessing.Array
> E.g. here:
> https://github.com/lucadelu/grass-addons/blob/5ca56bdb8b3394ebeed23aa5b3240bf6690e51bf/src/raster/r.raoq.area/r.raoq.area.py#L81
> According to the post here: https://medium.com/analytics-vidhya/using-numpy-efficiently-between-processes-1bee17dcb01
> multiprocessing.Array is needed to put the numpy array into shared memory and avoid pickling.
> I have not tried or investigated myself, but maybe worth a try...
Yes I saw it but I didn't try before. I tried last days but I didn't
get any improvements, I will try in the coming days
> Cheers
> Stefan
ciao
Luca
www.lucadelu.org
