[GRASS-dev] About fixing existing tests
Adithya Ambapurkar adinayyu at gmail.com
Fri Apr 15 00:48:57 PDT 2022
I have selected test_gunittest_doctests.py file from .gunittest.cfg and
tried to run on jupyterlab on binder. I included the necessary grass code
and when i run it gives some error
Without the grass code if i run nothing happens
I also tried to run locally and installed grass, pytest, ipython packages
using pip but it gives grass.gunittest module not found error
This is the first test i am fixing so can you guide me the procedure
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220415/6da45597/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220415/6da45597/attachment-0001.obj>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220415/6da45597/attachment-0001.jpe>
