[GRASS-dev] About fixing exisiting test
Vaclav Petras wenzeslaus at gmail.com
Sun Apr 17 19:57:11 PDT 2022
On Sun, 17 Apr 2022 at 07:30, Adithya Ambapurkar <adinayyu at gmail.com> wrote:
> ...used %%python...
As I mentioned earlier, I don't recommend this approach, but yes, you can
(and have to) use this in the notebook. However, that's for the notebook
only. Unrelated to the actual test code.
> It ran all tests successfully but in output it says raster map not found.
This may or may not be a problem. If the tests pass, chances are it is the
correct and expected output. For example, if the test checks the behavior
when a non-existent raster map is used, the message is expected and inside
the test, it likely expects failure rather than success with, e.g., the
assertModuleFail function you have seen.
> ...How to convert it to pytest code as both are different and is there any
> documentation which compares gunittest and pytest. Pytest docs and
> gunittest docs are separate. Example for assertModule and assertModuleFail
> what is its equivalent in pytest.
This is all for the actual summer project including the documentation.
All pytest is experimental now and does not have any documentation.
However, general pytest documentation applies:
https://docs.pytest.org/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220417/fddfa674/attachment.html>
