[GRASS-dev] About pull request
Adithya Ambapurkar adinayyu at gmail.com
Mon Apr 18 06:20:00 PDT 2022
I have created pull requests for test_module_assertions.py and for updating
gunittest.cfg file. Check the pr if any mistake is there. Thank you sir for
your support and guidance. With your help I could create the first pull
request for osgeo. Should I test other files also in gunittest.cfg for gsoc
2022.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220418/27c8e8ed/attachment.html>
