[GRASS-dev] About pull request
Vaclav Petras wenzeslaus at gmail.com
Mon Apr 18 06:59:20 PDT 2022
Great. I have left a new round of reviews.
#2311 looks hopeful and #2310 is not necessary, so no further changes are
needed in either at this point. Focus on fixing some tests.
On Mon, 18 Apr 2022 at 09:20, Adithya Ambapurkar <adinayyu at gmail.com> wrote:
> I have created pull requests for test_module_assertions.py and for
> updating gunittest.cfg file. Check the pr if any mistake is there. Thank
> you sir for your support and guidance. With your help I could create the
> first pull request for osgeo. Should I test other files also in
> gunittest.cfg for gsoc 2022.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220418/de1ea66c/attachment.html>
