[GRASS-dev] hi
Daniel Torres nobeeakon at gmail.com
Wed Aug 3 05:56:16 PDT 2022
Hi guys,
going back to the search feature in the Grass website. I've taken a look at
the options in Hugo docs. I think it may not be the best approach to have a
client based search as it will require loading big pieces of data...  in
principle all pages, so loading ... all website pages + all manual pages
in a single page. Take this one for example:
https://gist.github.com/cmod/5410eae147e4318164258742dd053993 ; using Hugo
it creates a json from all pages and then in the search implementation it
loads a js library and the json.  Other options listed in Hugo's website
are paid, like Algolia.
 So, maybe it would be better to just take the other approach of using
Duckduckgo or google in the mean time?
On Mon, Aug 1, 2022 at 2:23 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Now, I see I misunderstood here. The Discussion is about the communication
> channels, not about the website. I guess my comments are still generally
> valid, but irrelevant here. Sorry for the noise.
> On Mon, 1 Aug 2022 at 14:58, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> ...but I should add: Let's see what works.
>> On Mon, 1 Aug 2022 at 14:56, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> There is no difference in discussing things in the PR or issue versus in
>>> a Discussion in terms of notifications, no? If it is about development, it
>>> should be part of this mailing list or the PRs/issues in the relevant repo.
>>> I don't see what Discussion would add here. ...that's of course different
>>> from considering the more "chatty" channels.
>>> On Mon, 1 Aug 2022 at 14:17, Daniel Torres <nobeeakon at gmail.com> wrote:
>>>> Venga, muchas gracias Veronica.
>>>> Nice, thanks, I'll open a discussion. I mean, I'm just joining and
>>>> possibly there are some downsides of doing so and most probaly it has
>>>> already been discussed, but I think it would be useful to ease the
>>>> communication.
>>>> On Mon, Aug 1, 2022 at 12:58 PM Veronica Andreo <veroandreo at gmail.com>
>>>> wrote:
>>>>> Hola Daniel,
>>>>> None of those at time, but you could open a new discussion in github
>>>>> (though that is in the main grass repo...)
>>>>> Vero
>>>>> El lun., 1 ago. 2022 19:51, Daniel Torres <nobeeakon at gmail.com>
>>>>> escribió:
>>>>>> thanks Veronica, then I'll  try with the ones suggested in Hugo
>>>>>> website
>>>>>> (is there another communication method you guys use, like Slack,
>>>>>> discord or something like kind of more direct or  quick questions and
>>>>>> stuff? )
>>>>>> On Mon, Aug 1, 2022 at 11:43 AM Veronica Andreo <veroandreo at gmail.com>
>>>>>> wrote:
>>>>>>> Hello Daniel,
>>>>>>> IIRC, I suggested using something similar to what wowchemy (former
>>>>>>> hugo academic) has, but the path chosen was different. Paulo, also made a
>>>>>>> suggestion, but I didn't have the time to try, honestly. I think it's all
>>>>>>> in the PRs and probably this issue too:
>>>>>>> https://github.com/OSGeo/grass-website/issues/19
>>>>>>> Vero
>>>>>>> El lun, 1 ago 2022 a las 15:55, Daniel Torres (<nobeeakon at gmail.com>)
>>>>>>> escribió:
>>>>>>>> Thanks guys,
>>>>>>>> I'm ok with starting on the website.
>>>>>>>> About the search, in Hugo website they suggest a couple of methods
>>>>>>>> https://gohugo.io/tools/search/ , have those been tried?
>>>>>>>> On Sun, Jul 31, 2022 at 3:29 AM Veronica Andreo <
>>>>>>>> veroandreo at gmail.com> wrote:
>>>>>>>>> Hi Daniel,
>>>>>>>>> Welcome! Besides what Vashek pointed out, if you feel comfortable
>>>>>>>>> starting with something for the website, we are missing a search engine
>>>>>>>>> there. There were a couple of attempts in the past but none of them worked
>>>>>>>>> fully as expected. Have a look at the PRs here:
>>>>>>>>> https://github.com/OSGeo/grass-website/pulls
>>>>>>>>> Best,
>>>>>>>>> Vero
>>>>>>>>> El sáb, 30 jul 2022 a las 23:46, Vaclav Petras (<
>>>>>>>>> wenzeslaus at gmail.com>) escribió:
>>>>>>>>>> Hi Daniel,
>>>>>>>>>> Welcome. That sounds great. For Python, check this presentation
>>>>>>>>>> I'm preparing for FOSS4G where are I describe how to do good PRs which fix
>>>>>>>>>> coding standards and the load of tools which can be applied:
>>>>>>>>>> https://wenzeslaus.github.io/code-quality-measures-foss4g-2022/#/45
>>>>>>>>>> JavaScript at this point means starting with your own idea which
>>>>>>>>>> may or may not be what you are looking for. Website is certainly one option.
>>>>>>>>>> I would really like to see changes in the documentation (aka HTML
>>>>>>>>>> manual pages):
>>>>>>>>>> https://grass.osgeo.org/grass83/manuals/
>>>>>>>>>> ...but that's certainly "bring your own idea." It likely involves
>>>>>>>>>> some HTML and CSS design, but perhaps there is something more functional
>>>>>>>>>> that can be done. An alternative to this is migrating to Sphinx first, but
>>>>>>>>>> that's just a thought from the past.
>>>>>>>>>> Now when I think about it, the full JavaScript checks in
>>>>>>>>>> Super-Liner are not enabled, so that's perhaps a small JavaScript task to
>>>>>>>>>> tackle before starting a bigger project (that's up to you!).
>>>>>>>>>> Let me know if there is any other info which would be helpful.
>>>>>>>>>> Best,
>>>>>>>>>> Vaclav
>>>>>>>>>> On Sat, 30 Jul 2022 at 14:18, Daniel Torres <nobeeakon at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi guys, I'm Daniel , I work as Front end dev. I would like to
>>>>>>>>>>> contribute to the project, as I find it really nice. I have experience with
>>>>>>>>>>> JS and front end stuff, but also with Python.
>>>>>>>>>>> Happy to contribute, but don't really know where to start.
>>>>>>>>>>> (Maybe something on the website side?)
>>>>>>>>>>> Cheers,
>>>>>>>>>>>   Daniel
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> grass-dev mailing list
>>>>>>>>>>> grass-dev at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220803/b992eada/attachment.htm>
