[GRASS-dev] SIngle-Window GUI not working on Ubuntu 22.04
Paulo van Breugel p.vanbreugel at gmail.com
Wed Aug 24 02:36:16 PDT 2022
On Tue, Aug 23, 2022 at 12:07 PM Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi Paulo,
> if you are getting the same problem, you should install the latest
> wxPython:
> pip install -U -f
> https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-22.04/
> wxPython
> That should fix it. The wxPython in packages may be old and not patched,
> only 4.2.0 (released 2 weeks ago) has the fixes.
Brilliant, works like a charm, I don't even need to recompile grass. Thanks
Anna!
> Anna
> On Wed, Aug 17, 2022 at 9:05 AM Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> Dear devs,
>> I just upgraded to the latest Ubuntu LT (22.04) and recompiled GRASS GIS.
>> Unfortunately, the singe-window GUI does not work anymore.
>> This problem was reported as a bug earlier, see
>> https://github.com/OSGeo/grass/issues/2466, but I can't make the
>> proposed solutions work. I wonder if this is on the radar, and if there are
>> directions for a easier and more permanent solution, so we can enjoy this
>> great new feature on Ubuntu as well.
>> Cheers,
>> Paulo
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220824/33e6ad76/attachment-0001.htm>
