[GRASS-dev] Pre-release GRASS GIS 7.8.8RC3
Markus Neteler neteler at osgeo.org
Sun Dec 18 12:30:52 PST 2022
- Announcement -
GRASS GIS 7.8.8RC3
Repository: OSGeo/grass <https://github.com/OSGeo/grass> · Tag: 7.8.8RC3
<https://github.com/OSGeo/grass/tree/7.8.8RC3> · Commit: d02ffba
<https://github.com/OSGeo/grass/commit/d02ffba22e8186188773301dc0512c58fb26b7e5>
· Released by: neteler <https://github.com/neteler>
The GRASS GIS 7.8.8RC3 release provides more than 20 improvements and fixes
with respect to the release 7.8.8RC2.
What's Changed Graphical User Interface
   - wxGUI/forms: fix LayersList widget binding check/uncheck event method (
   #2495 <https://github.com/OSGeo/grass/pull/2495>) by @tmszi
   <https://github.com/tmszi>
   - wxGUI/gui_core: fix Create or edit image group dialog Select all
   CheckBox widget for selecting all items (#2514
   <https://github.com/OSGeo/grass/pull/2514>) by @tmszi
   - wxGUI/gui_core: fix imagery create/edit group dialog deselect all maps
   (#2465 <https://github.com/OSGeo/grass/pull/2465>) by @tmszi
   - wxGUI/lmgr: fix launch GCP Manager if not map display is activated (
   #2464 <https://github.com/OSGeo/grass/pull/2464>) by @tmszi
   - wxGUI/modules: fix import SQLite geometry data (#2491
   <https://github.com/OSGeo/grass/pull/2491>) by @tmszi
   - wxGUI/psmap: Ghostscript HyperlinkDialog is needed (#2441
   <https://github.com/OSGeo/grass/pull/2441>) by @tmszi
   - wxGUI/psmap: don't set StatusBar widget text when frame is closed (
   #2487 <https://github.com/OSGeo/grass/pull/2487>) by @tmszi
   - wxGUI/vdigit: fix keyboard shortcut for activating point/line tool (
   #2522 <https://github.com/OSGeo/grass/pull/2522>) by @tmszi
   - wxGUI/vselect: fix output fully qualified vector name (#2483
   <https://github.com/OSGeo/grass/pull/2483>) by @tmszi
   - wxGUI: fix manual page "GUI index" link html file name (#2461
   <https://github.com/OSGeo/grass/pull/2461>) by @tmszi
   - wxGUI: remove unnecessary key press event handlers (#2528
   <https://github.com/OSGeo/grass/pull/2528>) by @tmszi
Python
   - grass.pygrass: GridModule clean up temporary mapsets when exception
   occurs (#2614 <https://github.com/OSGeo/grass/pull/2614>) by @tmszi
Documentation and Messages
   - man: allow register all addons keywords in main Keywords Index (#2529
   <https://github.com/OSGeo/grass/pull/2529>) by @tmszi
   - man: use relative path for core modules man HTML page (#2574
   <https://github.com/OSGeo/grass/pull/2574>) by @tmszi
   - mkhtml: use UTF-8 for decoding git log messages by (#2533
   <https://github.com/OSGeo/grass/pull/2533>) @landam
   <https://github.com/landam>
Other Changes
   - Remove Travis CI for 7.8 (#2546
   <https://github.com/OSGeo/grass/pull/2546>) by @wenzeslaus
   <https://github.com/wenzeslaus>
   - SEO and manuals: add viewport and page language (#2591
   <https://github.com/OSGeo/grass/pull/2591>) by @neteler
   - general/g.mapsets: fix write MAPSETS without additional empty new line
   (#2586 <https://github.com/OSGeo/grass/pull/2586>) by @tmszi
   - python/grass/pygrass: reset back MAPSET search path after GridModule
   class instance finish (#2567 <https://github.com/OSGeo/grass/pull/2567>)
   by @tmszi <https://github.com/tmszi>
*Full Changelog*: 7.8.8RC2...7.8.8RC3
<https://github.com/OSGeo/grass/compare/7.8.8RC2...7.8.8RC3>
[image: Binder]
<https://mybinder.org/v2/gh/OSGeo/grass/7.8.8RC3?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fjupyter_example.ipynb>
This release has 2 assets:
   - Source code (zip)
   <https://github.com/OSGeo/grass/archive/refs/tags/7.8.8RC3.zip>
   <https://github.com/OSGeo/grass/archive/refs/tags/7.8.8RC3.tar.gz>
   - Source code (tar.gz)
Visit the release page
<https://github.com/OSGeo/grass/releases/tag/7.8.8RC3> to download them.
Thanks to all contributors!
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221218/5a764ff9/attachment.htm>
