[GRASS-dev] Pre-release GRASS GIS 7.8.8RC3
Martin Landa landa.martin at gmail.com
Mon Dec 19 14:56:18 PST 2022
Dear all,
Windows installer available for testing:
https://grass.osgeo.org/grass78/binary/mswindows/native/x86_64/WinGRASS-7.8.8RC3-1-Setup-x86_64.exe
Martin
ne 18. 12. 2022 v 21:31 odesílatel Markus Neteler <neteler at osgeo.org>
napsal:
> - Announcement -
> GRASS GIS 7.8.8RC3
> Repository: OSGeo/grass <https://github.com/OSGeo/grass> · Tag: 7.8.8RC3
> <https://github.com/OSGeo/grass/tree/7.8.8RC3> · Commit: d02ffba
> <https://github.com/OSGeo/grass/commit/d02ffba22e8186188773301dc0512c58fb26b7e5>
> · Released by: neteler <https://github.com/neteler>
> The GRASS GIS 7.8.8RC3 release provides more than 20 improvements and
> fixes with respect to the release 7.8.8RC2.
> What's Changed Graphical User Interface
>    - wxGUI/forms: fix LayersList widget binding check/uncheck event
>    method (#2495 <https://github.com/OSGeo/grass/pull/2495>) by @tmszi
>    <https://github.com/tmszi>
>    - wxGUI/gui_core: fix Create or edit image group dialog Select all
>    CheckBox widget for selecting all items (#2514
>    <https://github.com/OSGeo/grass/pull/2514>) by @tmszi
>    - wxGUI/gui_core: fix imagery create/edit group dialog deselect all
>    maps (#2465 <https://github.com/OSGeo/grass/pull/2465>) by @tmszi
>    - wxGUI/lmgr: fix launch GCP Manager if not map display is activated (
>    #2464 <https://github.com/OSGeo/grass/pull/2464>) by @tmszi
>    - wxGUI/modules: fix import SQLite geometry data (#2491
>    <https://github.com/OSGeo/grass/pull/2491>) by @tmszi
>    - wxGUI/psmap: Ghostscript HyperlinkDialog is needed (#2441
>    <https://github.com/OSGeo/grass/pull/2441>) by @tmszi
>    - wxGUI/psmap: don't set StatusBar widget text when frame is closed (
>    #2487 <https://github.com/OSGeo/grass/pull/2487>) by @tmszi
>    - wxGUI/vdigit: fix keyboard shortcut for activating point/line tool (
>    #2522 <https://github.com/OSGeo/grass/pull/2522>) by @tmszi
>    - wxGUI/vselect: fix output fully qualified vector name (#2483
>    <https://github.com/OSGeo/grass/pull/2483>) by @tmszi
>    - wxGUI: fix manual page "GUI index" link html file name (#2461
>    <https://github.com/OSGeo/grass/pull/2461>) by @tmszi
>    - wxGUI: remove unnecessary key press event handlers (#2528
>    <https://github.com/OSGeo/grass/pull/2528>) by @tmszi
> Python
>    - grass.pygrass: GridModule clean up temporary mapsets when exception
>    occurs (#2614 <https://github.com/OSGeo/grass/pull/2614>) by @tmszi
> Documentation and Messages
>    - man: allow register all addons keywords in main Keywords Index (#2529
>    <https://github.com/OSGeo/grass/pull/2529>) by @tmszi
>    - man: use relative path for core modules man HTML page (#2574
>    <https://github.com/OSGeo/grass/pull/2574>) by @tmszi
>    - mkhtml: use UTF-8 for decoding git log messages by (#2533
>    <https://github.com/OSGeo/grass/pull/2533>) @landam
>    <https://github.com/landam>
> Other Changes
>    - Remove Travis CI for 7.8 (#2546
>    <https://github.com/OSGeo/grass/pull/2546>) by @wenzeslaus
>    <https://github.com/wenzeslaus>
>    - SEO and manuals: add viewport and page language (#2591
>    <https://github.com/OSGeo/grass/pull/2591>) by @neteler
>    - general/g.mapsets: fix write MAPSETS without additional empty new
>    line (#2586 <https://github.com/OSGeo/grass/pull/2586>) by @tmszi
>    - python/grass/pygrass: reset back MAPSET search path after GridModule
>    class instance finish (#2567 <https://github.com/OSGeo/grass/pull/2567>)
>    by @tmszi <https://github.com/tmszi>
> *Full Changelog*: 7.8.8RC2...7.8.8RC3
> <https://github.com/OSGeo/grass/compare/7.8.8RC2...7.8.8RC3>
> [image: Binder]
> <https://mybinder.org/v2/gh/OSGeo/grass/7.8.8RC3?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fjupyter_example.ipynb>
> This release has 2 assets:
>    - Source code (zip)
>    <https://github.com/OSGeo/grass/archive/refs/tags/7.8.8RC3.zip>
>    <https://github.com/OSGeo/grass/archive/refs/tags/7.8.8RC3.tar.gz>
>    - Source code (tar.gz)
> Visit the release page
> <https://github.com/OSGeo/grass/releases/tag/7.8.8RC3> to download them.
> Thanks to all contributors!
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221219/d35a7ee2/attachment.htm>
