[GRASS-dev] GRASS 8.0 support in GDAL and QGIS
Vaclav Petras wenzeslaus at gmail.com
Fri Feb 25 05:20:52 PST 2022
On Fri, 25 Feb 2022 at 01:25, Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 2/24/22 15:23, Vaclav Petras wrote:
> > On Thu, 24 Feb 2022 at 03:33, Sebastiaan Couwenberg wrote:
> >> Should we perhaps take this opportunity to move the grass libraries to
> >> default library search paths as raised on the debian-gis list?
> >>    https://lists.debian.org/debian-gis/2021/12/msg00023.html
> > I vote yes. I think the reasons to do this are no longer valid. Doing it
> > the standard way seems to me to be the best way forward. Any
> > suggestions/PRs?
> Not using --prefix=/usr/lib will violate FHS, so not an option for the
> Debian package.
Using --prefix now results in every file from GRASS being installed into
--prefix, so I assume the current --prefix behavior is wrong from Debian
perspective, yes? Any suggestions on correct behavior?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20220225/fb4acd17/attachment-0001.html>
