[GRASS-dev] GRASS 8.0 support in GDAL and QGIS
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Feb 25 06:06:35 PST 2022
On 2/25/22 14:20, Vaclav Petras wrote:
> On Fri, 25 Feb 2022 at 01:25, Sebastiaan Couwenberg wrote:
>> On 2/24/22 15:23, Vaclav Petras wrote:
>>> On Thu, 24 Feb 2022 at 03:33, Sebastiaan Couwenberg wrote:
>>>> Should we perhaps take this opportunity to move the grass libraries to
>>>> default library search paths as raised on the debian-gis list?
>>>> https://lists.debian.org/debian-gis/2021/12/msg00023.html
>>> I vote yes. I think the reasons to do this are no longer valid. Doing it
>>> the standard way seems to me to be the best way forward. Any
>>> suggestions/PRs?
>> Not using --prefix=/usr/lib will violate FHS, so not an option for the
>> Debian package.
> Using --prefix now results in every file from GRASS being installed into
> --prefix, so I assume the current --prefix behavior is wrong from Debian
> perspective, yes? Any suggestions on correct behavior?
The 8.x prefix behavior is no different from 7.x.
If we want to stop using --prefix=/usr/lib and have FHS complianance
while also having the shared libraries in the default library search
path several changes in GRASS will be required.
The resulting structure should result in something like:
/etc/grass configuration files
/usr/bin executables
/usr/lib shared libraries
/usr/lib/python3/dist-packages/grass python package
/usr/libexec/grass executable helpers
/usr/share/grass architecture independent files
/usr/share/man manual pages
This assumes that the grass shared libraries should not be considered
private which does seem to be the case with their use by libgdal-grass
being the exception.
Alternatively the GRASS executables need to have RPATH set, e.g. with:
-Wl,-rpath,/usr/lib/grass80/lib
To remove the need for changing the library search path. This is the
road of least resistance.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
