[GRASS-dev] no icons in the first toolbar Grass 8.2.2
Anna Petrášová kratochanna at gmail.com
Mon Apr 10 08:02:25 PDT 2023
Using pip you should be able to install newest wxPython:
pip install -U -f
https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-22.04
wxPython
On Sun, Apr 9, 2023 at 9:15 PM Lizardo Reyna via grass-dev <
grass-dev at lists.osgeo.org> wrote:
> Thanks Markus,
> I'll try to install the patches to solve the problem. Then, I'll comment.
> Regards
> Lizardo
> On 2023-04-09 14:31, Markus Neteler wrote:
> Hi Lizardo,
> On Sun, Apr 9, 2023 at 5:10 PM Lizardo Reyna via grass-dev
> <grass-dev at lists.osgeo.org> wrote:
> Hi,
> I've compiled Grass 8.2.2 in ubuntu 22.04 (two times), the first toolbar
> do not have icons, only the description appers. The console shows this:
> Traceback (most recent call last):
>   File "/usr/lib/python3/dist-
> packages/wx/lib/agw/aui/auibar.py", line 3510, in OnPaint
> self._art.DrawButton(dc, self, item, item_rect)
> packages/wx/lib/agw/aui/auibar.py", line 1008, in DrawButton
> bmp_rect, text_rect = self.GetToolsPosition(dc, item, rect)
> packages/wx/lib/agw/aui/auibar.py", line 1508, in
> GetToolsPosition
> bmp_rect = wx.Rect(bmp_x, bmp_y, bmp_width, bmp_height)
> TypeError
> Rect(): arguments did not match any overloaded call:
>   overload 1: too many arguments
>   overload 2: argument 1 has unexpected type 'float'
>   overload 3: argument 1 has unexpected type 'float'
>   overload 4: argument 1 has unexpected type 'float'
>   overload 5: argument 1 has unexpected type 'float'
>   overload 6: argument 1 has unexpected type 'float'
> You are hit by a bug in Ubuntu's wxpython4 package. Unlike e.g. Fedora
> they didn't add missing backports of float -> integer fixes.
> It was also discussed here:
> https://github.com/OSGeo/grass/issues/2019
> https://github.com/OSGeo/grass/issues/2078
> We had the same in OSGeoLive, I have created a report with bugfixes
> for Ubuntu here:
> https://bugs.launchpad.net/ubuntu/+source/wxpython4.0/+bug/2012205
> These options I see:
> - you install the patches offered in the bug report (not too difficult
> but needs a bit of knowledge how to use `patch`)
> - convince the Ubuntu packagers of wxpython4 to fix the bug using the
> provided patch
> - you try to install a more recent wxpython4 version.
> Best,
> Markus
> Lizardo Reyna, PhD
> Universidad Técnica de Manabí
> [Address] Lodana, Manabí, Ecuador | [Mobile]  +593  982924637
> PGP Key: 0xa35a15b90ee64e8d
> Lizardo Reyna, PhD
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230410/decdade3/attachment.htm>
