[GRASS-dev] no icons in the first toolbar Grass 8.2.2
Lizardo Reyna farliz at disroot.org
Sun Apr 9 18:15:13 PDT 2023
Thanks Markus,
I'll try to install the patches to solve the problem. Then, I'll
comment.
Regards
Lizardo
On 2023-04-09 14:31, Markus Neteler wrote:
> Hi Lizardo,
> On Sun, Apr 9, 2023 at 5:10 PM Lizardo Reyna via grass-dev
> <grass-dev at lists.osgeo.org> wrote:
>> Hi,
>> I've compiled Grass 8.2.2 in ubuntu 22.04 (two times), the first
>> toolbar do not have icons, only the description appers. The console
>> shows this:
>> Traceback (most recent call last):
>> File "/usr/lib/python3/dist-
>> packages/wx/lib/agw/aui/auibar.py", line 3510, in OnPaint
>> self._art.DrawButton(dc, self, item, item_rect)
>> packages/wx/lib/agw/aui/auibar.py", line 1008, in DrawButton
>> bmp_rect, text_rect = self.GetToolsPosition(dc, item, rect)
>> packages/wx/lib/agw/aui/auibar.py", line 1508, in
>> GetToolsPosition
>> bmp_rect = wx.Rect(bmp_x, bmp_y, bmp_width, bmp_height)
>> TypeError
>> Rect(): arguments did not match any overloaded call:
>> overload 1: too many arguments
>> overload 2: argument 1 has unexpected type 'float'
>> overload 3: argument 1 has unexpected type 'float'
>> overload 4: argument 1 has unexpected type 'float'
>> overload 5: argument 1 has unexpected type 'float'
>> overload 6: argument 1 has unexpected type 'float'
> You are hit by a bug in Ubuntu's wxpython4 package. Unlike e.g. Fedora
> they didn't add missing backports of float -> integer fixes.
> It was also discussed here:
> https://github.com/OSGeo/grass/issues/2019
> https://github.com/OSGeo/grass/issues/2078
> We had the same in OSGeoLive, I have created a report with bugfixes
> for Ubuntu here:
> https://bugs.launchpad.net/ubuntu/+source/wxpython4.0/+bug/2012205
> These options I see:
> - you install the patches offered in the bug report (not too difficult
> but needs a bit of knowledge how to use `patch`)
> - convince the Ubuntu packagers of wxpython4 to fix the bug using the
> provided patch
> - you try to install a more recent wxpython4 version.
> Best,
> Markus
>> Lizardo Reyna, PhD
>> Universidad Técnica de Manabí
>> [Address] Lodana, Manabí, Ecuador | [Mobile]  +593  982924637
>> PGP Key: 0xa35a15b90ee64e8d
Lizardo Reyna, PhD
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230409/e1025b7b/attachment.htm>
