[GRASS-dev] [EXTERNAL] [release planning] GRASS GIS 8.3.1
Nicklas Larsson n_larsson at yahoo.com
Wed Sep 20 08:31:28 PDT 2023
https://github.com/OSGeo/grass/issues/3077 <https://github.com/OSGeo/grass/issues/3077>
_is_ the one and only blocker for 8.3.1. :
https://github.com/OSGeo/grass/issues?q=is%3Aopen+is%3Aissue+label%3A%22backport+to+8.3%22+label%3Ablocker <https://github.com/OSGeo/grass/issues?q=is:open+is:issue+label:%22backport+to+8.3%22+label:blocker>
N.
> On 20 Sep 2023, at 17:14, Newcomb, Doug <doug_newcomb at fws.gov> wrote:
> I wouldn't mind seeing the fix to g.extension for Windows that just went in, so you can load addons  on Windows in 8.3.x https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938 <https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938>
> g.extension: fix installing addons on the OS MS Windows by tmszi · Pull Request #3166 · OSGeo/grass <https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938>
> Fixes #3077. Fix installing addons via g.extension module on the OS MS Windows without dependency on Git program. Gettings official GitHub addons repository branches g.extension -l is based on the ...
> github.com <http://github.com/>
> From: grass-dev <grass-dev-bounces at lists.osgeo.org <mailto:grass-dev-bounces at lists.osgeo.org>> on behalf of Nicklas Larsson via grass-dev <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>
> Sent: Wednesday, September 20, 2023 4:14 AM
> To: Markus Neteler <neteler at osgeo.org <mailto:neteler at osgeo.org>>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>
> Subject: [EXTERNAL] Re: [GRASS-dev] [release planning] GRASS GIS 8.3.1
>  This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
> In general, I wouldn’t mind a quick patch 8.3.1 release. Remaining (non-blocking) issues may be bumped to 8.3.2, which in turn can be released as soon as possible.
> The changes since 8.3.0:
> https://github.com/OSGeo/grass/compare/8.3.0...OSGeo:grass:releasebranch_8_3?expand=1 <https://github.com/OSGeo/grass/compare/8.3.0...OSGeo:grass:releasebranch_8_3?expand=1>
> Best,
> Nicklas
>> On 19 Sep 2023, at 21:33, Markus Neteler <neteler at osgeo.org <mailto:neteler at osgeo.org>> wrote:
>> Any other opinions?
>> What about the Windows g.extension git story, to be added to 8.3.1?
>> Markus
>> On Mon, Sep 11, 2023 at 1:48 PM Newcomb, Doug <doug_newcomb at fws.gov <mailto:doug_newcomb at fws.gov>> wrote:
>>> This is an important function of GRASS. I think it would be wise to rectify the issue as soon as possible
>>> ________________________________
>>> From: grass-dev <grass-dev-bounces at lists.osgeo.org <mailto:grass-dev-bounces at lists.osgeo.org>> on behalf of Markus Neteler <neteler at osgeo.org <mailto:neteler at osgeo.org>>
>>> Sent: Monday, September 11, 2023 6:26 AM
>>> To: GRASS developers list <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>>
>>> Subject: [EXTERNAL] [GRASS-dev] [release planning] GRASS GIS 8.3.1
>>> Hi devs,
>>> While 8.3.0 has been released rather recently, an important bug showed up:
>>> - r.watershed: fix streams and basins #3140
>>> Unfortunately r.watershed is partially broken in 8.3.0 such that
>>> streams and basins are no longer correctly calculated. This has been
>>> now been fixed.
>>> Given the importance of r.watershed, I suggest an anticipated release of 8.3.1
>>> Here the milestone:
>>> https://github.com/OSGeo/grass/milestone/21 <https://github.com/OSGeo/grass/milestone/21>
>>> What do you think?
>>> Markus
>>> grass-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230920/13361da8/attachment-0001.htm>
