[GRASS-dev] [EXTERNAL] Re: [release planning] GRASS GIS 8.3.1
Newcomb, Doug doug_newcomb at fws.gov
Wed Sep 20 08:14:12 PDT 2023
I wouldn't mind seeing the fix to g.extension for Windows that just went in, so you can load addons  on Windows in 8.3.x https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938
[https://opengraph.githubassets.com/f9d53daef25fcfb526eac15d1abc3b2f3aab12de75e83651422088b0bd791720/OSGeo/grass/pull/3166]<https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938>
g.extension: fix installing addons on the OS MS Windows by tmszi · Pull Request #3166 · OSGeo/grass<https://github.com/OSGeo/grass/pull/3166#issuecomment-1727462938>
Fixes #3077. Fix installing addons via g.extension module on the OS MS Windows without dependency on Git program. Gettings official GitHub addons repository branches g.extension -l is based on the ...
github.com
From: grass-dev <grass-dev-bounces at lists.osgeo.org> on behalf of Nicklas Larsson via grass-dev <grass-dev at lists.osgeo.org>
Sent: Wednesday, September 20, 2023 4:14 AM
To: Markus Neteler <neteler at osgeo.org>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [GRASS-dev] [release planning] GRASS GIS 8.3.1
 This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
In general, I wouldn’t mind a quick patch 8.3.1 release. Remaining (non-blocking) issues may be bumped to 8.3.2, which in turn can be released as soon as possible.
The changes since 8.3.0:
https://github.com/OSGeo/grass/compare/8.3.0...OSGeo:grass:releasebranch_8_3?expand=1
Best,
Nicklas
On 19 Sep 2023, at 21:33, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
Any other opinions?
What about the Windows g.extension git story, to be added to 8.3.1?
Markus
On Mon, Sep 11, 2023 at 1:48 PM Newcomb, Doug <doug_newcomb at fws.gov<mailto:doug_newcomb at fws.gov>> wrote:
This is an important function of GRASS. I think it would be wise to rectify the issue as soon as possible
From: grass-dev <grass-dev-bounces at lists.osgeo.org<mailto:grass-dev-bounces at lists.osgeo.org>> on behalf of Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
Sent: Monday, September 11, 2023 6:26 AM
To: GRASS developers list <grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>>
Subject: [EXTERNAL] [GRASS-dev] [release planning] GRASS GIS 8.3.1
Hi devs,
While 8.3.0 has been released rather recently, an important bug showed up:
- r.watershed: fix streams and basins #3140
Unfortunately r.watershed is partially broken in 8.3.0 such that
streams and basins are no longer correctly calculated. This has been
now been fixed.
Given the importance of r.watershed, I suggest an anticipated release of 8.3.1
Here the milestone:
https://github.com/OSGeo/grass/milestone/21
What do you think?
Markus
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20230920/0bfcf38f/attachment.htm>
