[GRASS-dev] [GRASS-user] GRASS-Wiki: new OSGeo-ID login method activated
Veronica Andreo veroandreo at gmail.com
Wed Feb 14 04:55:05 PST 2024
Thanks for taking care of this, Markus!
I just tested, all seems to be working.
Cheers,
Vero
El mar, 13 feb 2024 a las 15:09, Markus Neteler via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Dear all,
> As of February 2024, we are happy to announce that the GRASS Wiki (
> https://grasswiki.osgeo.org/wiki/) is connected to the OSGeo
> authentication system!
> Many thanks to Regina Obe from OSGeo-SAC (
> https://wiki.osgeo.org/wiki/User:Robe).
> *What does it mean?*
> In order to keep spammers out of the system and to simplify the overall
> OSGeo login experience, the centralized OSGeo login method is also
> activated for the GRASS GIS Wiki.
> Please note that your current GRASS-Wiki username/password will no longer
> work here in favor of the OSGeo-ID already used elsewhere (OSGeo-Wiki etc.).
> *What do I need to log in?*
> As before, no login is required to read the wiki content.
> To edit the Wiki, you need to login with your OSGeo-ID (technically your
> OSGeo-LDAP account). If you do not have an OSGeo-ID yet, please register
> here: https://www.osgeo.org/community/getting-started-osgeo/osgeo_userid/
> *What if I already have a GRASS-Wiki account?*
> The first time you log in to the GRASS-Wiki with your OSGeo-ID, your
> existing old user account will be merged with the OSGeo-ID. This should
> work automatically. If not, please contact me directly.
> Feel free to ask if you have any questions.
> Best regards,
> Markus
> Markus Neteler, PhD
> https://www.mundialis.de - company
> https://grass.osgeo.org - FOSS
> https://neteler.org - freelancing & blog
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240214/64b1d8e3/attachment.htm>
