[GRASS-dev] GRASS GIS: backport of CI speed updates to G83?
Markus Neteler neteler at osgeo.org
Tue Feb 20 01:14:04 PST 2024
On Tue, Feb 20, 2024 at 1:59 AM Edouard Choinière <e.chs at outlook.com> wrote:
> I don’t know a lot about backporting,
If "lucky", then it is just
git cherry-pick <hash>
> but if you’re talking about splitting of the Ubuntu workflow’s gunittest tests, I don’t see a reason why the content of the changes couldn’t be copied to a new commit for that branch too. Since they are ran less often, the tests could be split in three or even 4 jobs, where the %of time spent compiling the same code would be a bit higher, but the time for all tests to run could be smaller. The tests in the temporal folder still take half the total test time though.
> If you are talking about the macOS arm runner, it might require some other changes to port. My opinion would be to leave that alone in the 8.3 as pre-arm code. But the same splitting could easily be done for 8.3, and split as wished.
In fact the slowest CI run determines how much time I have to wait
with each release step (i.e., editing VERSION file, wait 1:30hs, do
some steps, wait 1:30hs, create tarball, wait 1:30hs, reset VERSION
file, wait 1:30hs ... which is a pain).
> In main, for macOS workflows, with only 20-25 mins spent on tests, with 3-4 min spent on compiling, I don’t see the need to split it.
Okay.
> Windows workflows I don’t think it’s advantageous, as more than 20 mins is spent before starting tests.
Alright.
Perhaps I have simply go through it again and hope that we abandon 8.3 soon :-)
Best
Markus
