[GRASS-dev] GRASS GIS: backport of CI speed updates to G83?
Nicklas Larsson n_larsson at yahoo.com
Tue Feb 20 03:44:48 PST 2024
> On 20 Feb 2024, at 10:14, Markus Neteler via grass-dev <grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>> wrote:
> In fact the slowest CI run determines how much time I have to wait
> with each release step (i.e., editing VERSION file, wait 1:30hs, do
> some steps, wait 1:30hs, create tarball, wait 1:30hs, reset VERSION
> file, wait 1:30hs ... which is a pain).
I agree this is a case where we have limited ourself too much, with all those
required 1.5 hrs tests, approval, etc. (not even [skip ci] would work) . What you
would need is a (ideally) direct commit access or at least  “Rebase and merge”
option to merge (thus enable a number of commits to be merged at one time,
as opposed to "Squash and merge”).
We must find a solution to improve this situation for preparing releases, I
wouldn’t mind temporary lifting necessary constraints.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240220/b0f8f630/attachment.htm>
