[GRASS-dev] configurare fails: Failed check for math library
Martin Landa landa.martin at gmail.com
Wed Jan 24 05:59:00 PST 2024
st 24. 1. 2024 v 14:46 odesílatel Nicklas Larsson <n_larsson at yahoo.com>
napsal:
> Another thought, configure fails at locating the math library which is
> part of standard C library. If not installed, you’ll probably need `glibc`.
it would be strange that this core dependency wouldn't be installed by `apt
build-dep grass`. I checked:
martin at katovice:~/src/grass$ apt policy libc6-dev
libc6-dev:
  Installed: 2.37-13
  Candidate: 2.37-13
  Version table:
 *** 2.37-13 500
        500 http://deb.debian.org/debian testing/main amd64 Packages
        100 /var/lib/dpkg/status
it should be fine. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240124/ab227a21/attachment.htm>
