[GRASS-dev] configurare fails: Failed check for math library
Nicklas Larsson n_larsson at yahoo.com
Wed Jan 24 06:22:25 PST 2024
I too would have been surprised if glibc wasn’t there. (I’m shooting from the hips :-).
You can investigate the "config.log” for hopefully more detailed information on why the math library configure test failed.
> On 24 Jan 2024, at 14:59, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> st 24. 1. 2024 v 14:46 odesílatel Nicklas Larsson <n_larsson at yahoo.com <mailto:n_larsson at yahoo.com>> napsal:
>> Another thought, configure fails at locating the math library which is part of standard C library. If not installed, you’ll probably need `glibc`.
> it would be strange that this core dependency wouldn't be installed by `apt build-dep grass`. I checked:
> martin at katovice:~/src/grass$ apt policy libc6-dev
> libc6-dev:
>   Installed: 2.37-13
>   Candidate: 2.37-13
>   Version table:
>  *** 2.37-13 500
>         500 http://deb.debian.org/debian testing/main amd64 Packages
>         100 /var/lib/dpkg/status
> it should be fine. Martin
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240124/a4818431/attachment.htm>
