[GRASS-dev] GRASS Teams on GitHub
Even Rouault even.rouault at spatialys.com
Tue Mar 12 17:57:22 PDT 2024
FYI I see this thread referencing the GDAL github team organization. As
far as I know, nobody has "designed" it with deep thoughts. It has the
current structure most likely as an accident of history... If I were to
design it, I would keep it simple and stupid. With git workflows, the
concept of "committer" as in SVN era is kinda irrelevant. You just need
a sufficient number of people with appropriate push rights to merge the
flow of incoming PRs, but if you have more than 10 people with push
rights in a single repo, that is already quite big. My 2 cents, and
running away as I've no idea how the GRASS team works ;-)
Le 13/03/2024 à 01:35, Vaclav Petras via grass-dev a écrit :
> On Fri, 8 Mar 2024 at 09:10, Ondřej Pešek <pesej.ondrek at gmail.com> wrote:
>     @Vaclav: Do you have some more points against the master-children
>     schema? It seems that the general agreement is *for* the restructuring
>     into parent and children teams. So far the only point against was "I
>     didn't find team nesting particularly useful and we already had a
>     couple of top-level teams."
> ...and I didn't see it working for GDAL with people both in the parent
> team and child teams and repos being assigned to both levels.
> How do you suggest we do it? Empty parent team without repos? Would
> that look good?
>     Although I appreciate all the work you
>     dedicate to the GitHub management, I don't think that this is a valid
>     point against when compared to the positive ones (although it's
>     understandable that nobody wants to drop something that they have just
>     created).
> Thanks. It is more that before it was a high priority for me to get
> access rights in order (access rights to individuals both directly and
> through teams, inactive people from 2000s and early 2010s
> grandfathered into GitHub write access, ...). These parent-child teams
> are low priority compared to that.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240313/b653a63f/attachment.htm>
