[GRASS-dev] v.dissolve confusion
Michael Barton Michael.Barton at asu.edu
Fri Mar 15 16:59:54 PDT 2024
Any suggestions about what is wrong with either of the versions of this dissolve command?
v.dissolve --overwrite input=alcala_subsectors at SAA2024 column=ID output=alcala_subsectors_dissolved at SAA2024 aggregate_columns=group_concat(REGION),max(STRATUM),max(SECTOR),avg(SUBSECTOR),group_concat(SECTOR_ID),sum(AREA),group_concat(SURVEYED),avg(IDNUM) result_columns="region TEXT,stratum INTEGER,sector INTEGER,subsector REAL,sector_ID TEXT,area REAL,surveyed TEXT,IDnum REAL"
v.dissolve --overwrite input=alcala_subsectors at SAA2024 column=ID output=alcala_subsectors_dissolved at SAA2024 aggregate_columns=group_concat(REGION),max(STRATUM),max(SECTOR),avg(SUBSECTOR),group_concat(SECTOR_ID),sum(AREA),group_concat(SURVEYED),avg(IDNUM) result_columns="region,stratum,sector,subsector,sector_ID,area,surveyed,IDnum"
I'm trying to maintain my attribute table because of the great difficulty in reconnecting it. In both cases, I get the error:
Option <result_columns> requires all of <aggregate_columns>
I have the same number of result columns as I do aggregate columns with equivalent data types.
I have 8 columns (dissolved by the 9th column ID):
region TEXT
stratum INTEGER
sector INTEGER
subsector REAL
sector_ID TEXT
area REAL
surveyed TEXT
IDnum REAL
Michael
_____________________________
C. Michael Barton
Associate Director, School of Complex Adaptive Systems (https://scas.asu.edu<https://scas.asu.edu/>)
Professor, School of Human Evolution & Social Change (https://shesc.asu.edu)
Director, Center for Social Dynamics & Complexity (https://complexity.asu.edu)
Arizona State University
Tempe, AZ 85287-2701
USA
Executive Director, Open Modeling Foundation (https://openmodelingfoundation.github.io<https://openmodelingfoundation.github.io/>)
Director, Network for Computational Modeling in Social & Ecological Sciences (https://comses.net)
personal website: http://www.public.asu.edu/~cmbarton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20240315/6061181a/attachment.htm>
