[GRASSGUI] problem with i.samp module in GIU
Markus Neteler neteler at itc.it
Wed Apr 3 10:25:57 EST 2002
Hi anil,
thanks for your hint, I have fixed the tcltkgrass entry.
You can easily fix it locally, just edit the file
 $GISBASE/tcltkgrass/module/i.smap
when inside GRASS. Change
 sigfile
to
 signaturefile
Kind regards
 Markus Neteler
On Tue, Apr 02, 2002 at 06:16:55PM +0530, Anil Kumar Bhagat wrote:
> Dear Grass GUI developers
>                           When I run the i.samp module from GUI ,
> following error is coming . In command mode it is runing fine.
> Sorry, <sigfile> is not a valid parameter
> ERROR: Required parameter <signaturefile> not set:
>     (imagery signaturefile).
> Description:
>  An imagery function that performs contextual image classification using
> sequential maximum a posteriori (SMAP) estimation.
> Usage:
>  i.smap [-mq] group=name subgroup=name signaturefile=name
>    [blocksize=value] output=name
> Flags:
>   -m   Use maximum likelihood estimation (instead of smap)
>   -q   Run quietly
> Parameters:
>           group   imagery group
>        subgroup   imagery subgroup
>   signaturefile   imagery signaturefile
>       blocksize   size of submatrix to process at one time
>                   default: 128
>          output   output raster map
> Please help me in this regard .
> Anil Kumar Bhagat
> ( Project Asst. )
> Center For Ecological Science ,
> Indian Institute Of Science Banglore,
> Banglore .
> Phone : 3600985 ,3092506 ext-213
> grassgui mailing list
> grassgui at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassgui
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
More information about the grass-gui mailing list
