[GRASSGUI] help for setting default value
Markus Neteler neteler at itc.it
Wed Apr 3 10:34:23 EST 2002
On Sat, Mar 30, 2002 at 05:55:16PM +0530, Anil Kumar Bhagat wrote:
> Dear GRASS GUI developers ,
> I want to know how do you set default value of a particular input for
>  a module in GUI . For exampe in <d.3d> module
> from_coordinate   coordinates of view point
>                     default: 76.3161,12.0901,20000
>     to_coordinate   coordinates of center of view
>                     default: 78.08415,14.34115,0
>      exaggeration   vertical exaggeration factor
>                     default: 2.0
The values to enter depend from the current region settings.
> i.cluster is not runing from GUI . It is runing fine through command mode
What is the problem here? Please post the error message.
> Also when d.3d run through GRASS GUI it show different effect than command
> mode.
Sorry, no idea about this. Eventually you want to use "nviz" which is
much more convenient than d.3d.
Markus Neteler
More information about the grass-gui mailing list
